In the 96, the coolant is a little below the line in the overflow bottle in the morning, but once driven it goes up a bit. What can be causing this?
"Both my 96 and 98 have Napa 180 degree thermostats but the 96 doesn't have the ECU programmed for the colder thermostat."
If your changin from a stock t-stat to a 180 degree one, do you have to set the ECU for a colder thermostat? if so.. how is this done?
