Tony_1992
First thank you guys for your answers. I'm really addicted to this forum.
As it is becoming hotter in Florida, I sometimes found the fan in head starts to turn. I thought that's problem of cooling system.
And after checking the antifreeze, the level was fairly low. So I added some antifreeze to it's normal level. But after a day's driving, the level dropped about 2cm in normal speed. And I can see some water(I mean antifreeze) gathering on the cover underneath the car, and the cover was also very dirt. Maybe polluted by leaked antifreeze?
In that case, pressure test and dye UV test, which one should I do?
And by the way, in pressure test, is pump be connected to radiator cap? Where is the radiator?
Thank you guys.
Thank you guys.
