coolant leak on 2000 LS V8
pressley
Toronto
Hey Guys! I need a little help here, I recently replaced the coolant reservoir less than a month ago because the car overheated and they said that reservoir was cracked and it was leaking coolant. But 2 days ago i found a puddle of coolant underneth the car. I was hoping someone knows about this. Thanks in advance
had same problem. dealership cracked new resivoir putting it in.
oh thanks, did they admit that they cracked it putting it in? or they gave you a hard time?
I noticed mine has a bad plastic union block up by the radiator that cracked and is leaking. It is in line with the upper raidator hose and a smaller heater size hose comes off of it. Maybe if they were shifting stuff around in there they could have cracked that as well?
Where is the leak/puddle? If it's just behind the drivers side front wheel, approx 6-10 inches towards center of car (counting from outer edge of drivers side of car), chances are, it's the reservoir or hose coming from reservoir.
