Confused on how to hook up HIDs..
jtammerine
North Carolina
i pretty sure most of u are tire of reading these threads but can someone please help...the battery source is in the trunk.
The only ones I've used are plug and play type kits. If anything, tap into the fuse box under the hood.
with all due respect, if you are confused about setting up HID's, you should probably stay away from it.
I tapped into the fuse box. Well on my 04 there are some open slots where you get connect a plug, I got it from radio shack.
@ jtammerine what size are those rims on your LS?
The other option on Gen 1s aside from the above mentioned fuse box tap, is to utilize the power source coming into the fuse box on the right hand side of the box. It is a small bolt on that side that is a direct source from the battery, this worked perfect for my kit.
I'm thinking of doing this mod soon as well so let me know what you did and how it came out.
