Ron Brownie
I have a '93 Conti - 3.8 litre.
Recently I replaced: timing chain cover gasket, fuel pump gasket, and the water pump gasket (replaced the water pump 1,000km ago.). This because I had a major oil leak that turned out to be a failure of the timing chain cover gasket. Now having completed these things, the engine stalls whenever I first start it up. Generally when it's cold, but even if it has been driven for some time, then shut off for 1.5 hours. Seems to me as if there no longer is any provision for cold engine fast idle. Of course, the idle and timing are not adjustable. I did have the distributor in wrong initially (one tooth out), but corrected that. The alternator subsequently failed (probably because it was a used one that I bought for $50.00 - slap on the hand for that) and I replaced it with a new one, hoping that might be part of the problem, but no improvement. I have been experiencing the chronic problem with the electronic dash telling me that things aren't working when they actually are, and decided to get around that the lazy way (disconnected the buzzer thing).
Can anyone point me in the right direction, please???
