coil spring conversion?
godparag
michigan
Hi I keep losing my name and pass word I finally got my mark 8 Iput coil springs in it how do I get the message off the board any help would help thanks
the kick panel is in the car behind the glove. your disabling the check mesage arent u
Yup, kick panel is the small plastic carpeted panel just in front of the passenger door. Careful when you remove it - it has to be slid back towards the rear of the car, as it has a clip that will break if the panel is just tugged away.
zm
ya I saved this car from a guy that saved it. He got it for scrap because the air ride was out. He left it out in a field and the brake lines went out that suck but I got it done I got 800 into this car and its in good shape I just got to fix her up some. thanks for the help guys ill try to get some pics
