data shall set you free.
look at this screen cap from my last datalog at the track.
I placed the indicator at the peak RPM on that run, which was the 1-2 shift.
You can see the line that is red is the RPM trace and it peak at 6156
The yellow line is MAF AD counts, which translate into maf voltage in the lower right hand window in the MAF transfer function for a stock mark 8 that I added into this photo for reference.
at 6156 RPM's the MAF AD counts are at 883 out of 1024
883 AD counts is between 4.24volts and 4.49 volts out of a possible 5Volt range.
Clearly this shows the stock NA mark 8 has enough top end overhead with the stock air meter in place.
What happens when you put a larger meter on there, is you lose the bottom end "resolution" of the maf table, which means your part throttle and low RPM fuel control is limited...this is bad
Then when you go WOT rather than using MOST of the MAF sensors range you only use about half of the range....this is bad
When I had a larger maf on my first gen at WOT at 6K the maf voltage was 2.8-3.0 which if you look at the transfer function is only using the "bottom half" of the MAF transfer function...this is bad
From a tuning stand point this is bad..very bad.
