Cobra intake/FoMoCo throttle body swap?
Should I spend $175 for cobra intake/Fomoco TB?
  • Total voters
    11
Technically, no. A bit less turbulent, sure. Huge gain in power, no.
With that said, my Cobra intake is not stock either. It has minor dremel work on the ports and the extra casting on the lower plenum between all of the runners has been removed and ground back. But who knows. Maybe I would be running 14.0s without the dremel work. :shifty:
The truth comes out :shifty:
LOL I don't have any data to compare the difference from when the intake was stock condition but I bet not much was gained if that's what you are getting at. There are other factors in play that are keeping you behind me in terms of NA and I'm pretty sure you know what they are.
"Fastest Mark VIII in Norcal"
"Fastest NA Gen2 in the midwest"
You guys are too much. :p
Well actually I have the fastest NA Mark VIII from here all the way to Norcal if you want to get technical. Nitrous does not qualify as NA. :p
<--- Fastest MK8 in the WORLD (with march ram air) Does that count and sound as cool as others?
