cobra brake upgrade - no master change required?
purpony
CT
Just bought a front cobra brake kit for the lincoln...
I was just wondering since i have not seen any mention of it around here.. but the factory master cylinder is ok with these front calipers? no change required?
Bolt on and go?
using stock brake lines? anyone get the cobra brake lines to fit? or did you go custom. If so, what brand and how do you order?
Master cylinder is fine.
Fronts pretty much bolt on
I used stainless steel lines by paragon performance recomeneded by doug for a tbird
Stocks will work depending on the caliper others will chime in on this
Nice car btw.
On a side note how do you like the tokicos with vogtland s?
Doug (or anyone else that might happen to know), do you know what the end fittings and lengths are for the Mark VIII's?
thanks for the replys all
no input yet... just installed the fronts, rears are going on monday afternoon when i get some free time.
