04 Lincoln Ls V6. My dual climate control works at the extremes, 90 for heat, 60 for AC. Auto function does not appear to work properly. If I set auto temp at 72, I get mostly heat. I did a search on the DCCV, but that does not seem to be my problem as temps are consistent on driver and passenger fields.
One thing I noticed on my father-in-law's Gen 1 is that when you press the temp rocker switch both the passenger and driver's temps go up or down at the same time. On my Gen 2 they are independent, is this correct?
Any and all input appreciated, thanks.
