Christmas gift!
They actually used the pigment in the Canadian money. We had to do a Mustang up here and went through the same thing Jamie's buddy did but a little further. When we were finished the repair the PPG rep took everything with him again including the thinners we used to clean out the gun:eek:.
I have heard stories like this for the past 10 years. CraZy :runaway:
For the fun of it.
903070:PRIME DELTRON 2000 DBC MET: 903070: 2004-2004 MYSTICHROME : 3XTEWHA: FORD (N AMERICA) MMF Brand Reference: 903070 Finish Effect : Metallic Category: Good Match 1 Quart formula in parts Lead-Free Formula *Must use undercoat G7 for maximum hiding. WARNING: contains VM4989 limited use toner. Please check availability before mixing. Formula contains Harlequin, Review price code
Main Layer:903070 price code: XG MSDS number: DBC1 Revision Date 1/23/2004
Code Description Cum.
DMD649 Clear 158.30N
VM4989 GRN/PURPLE 474.80
DMD1607 BLUE 614.10
DMD1683 BLACK 682.50
DMD646 WEAK WHITE 688.20
DBX1689 CLEAR 1004.7
Mix away.. if you try to get a factory pack its near impossible. PPG Deltron is the way to go. The base coat is the black g7 epoxy sealed. Mid coat is the shift and then the clear.
