smegun
changing my cam cover gaskets thought I had some leaks burning on the rear pipes to my suprise there was oil in #8 plug tube and a smidge in #7 so I ordered a cam cover gasket set hopefully to fix the problem ...it wasn't all my problems evidently still have steam smoke coming off the pipes even after diligently doing the gaskets ….when she gets warmed up there is steamy smoke but she is purring better ….
I was at the high mark on the dip stick so I dropped a quart or close to avoid a possible slosh problem unfortunately when I looked at it I got choco milk ….dam I asked the forum earlier about head gaskets but was told this never happens when I look at my coolant reservoir it seem hardly effected its not a lot of steam or sputter but steamy like whitish light grey at best
was hoping my brake booster was feeding brake fluid as cause into my cats ...it all disappeared one night and had to park it I had a stiff pedal I mean no hydrolics I had been getting that white puffy smoke from back of engine so I changed the booster today but I still got no brakes.. shouldn't pull things from the yard and expect everything to go cherry the advance track is giving me a pain and I think I might have the front and rear swapped looking for a wire diagram that tells me the diff between the one with the brown white and the brown yellow I got the brown white closer to the front ...
