Check transmission / E code, 02 ls v8. Any help or advice is appreciated
General Discussion Forum
  1. T-Locc02
    T-Locc02 New LVC Member
    3
    Jan 16, 2018
    Albany oregon
    Just bought it a week ago, it started shifting hard and it feels like it' slipping also,
    Looking for some advice or help on it before I tare into it.
    Thanks!
  2. joegr
    joegr Dedicated LVC Member
    19,166
    1,337
    Dec 10, 2005
    Gulfport
    Read out the codes (need a Ford specific reader), and go from there.
    Somewhat common issues are:
    Solenoid assembly problem
    Valve body problem
    PCM problem (usually doesn't trigger the "E")
    Worn servo bore(s)
    Broken servo(s)
    If it's really slamming on the shifts, don't drive it. You'll break a band.
  3. T-Locc02
    3
    Jan 16, 2018
    Albany oregon
    Joegr. Thanks for the advice.
    It spit a P0745 code, PCA solenoid circuit failure - shorted circuit.
    I'm thinking replacing the shift solenoids will do the trick?
  4. joegr
    19,166
    1,337
    Dec 10, 2005
    Gulfport
    Yes, that will probably be all you need.
  5. T-Locc02
    3
    Jan 16, 2018
    Albany oregon
    Thanks, it's appreciated
Share This Page
