The other day while driving I received a Check Traction Control message; and the car died soon thereafter -- since then it will not start.
Cannot clear check traction control message -- no codes are stored.
Can't find any blown fuses or bad wires.
No fuel pressure present; everything (voltage from Inertial fuel switch) is fine to the REM but no voltage output to the fuel pump. It is as if the REM doesn't want to turn on the pump???
I can manually apply voltage to the fuel pump and and it will pump up to pressure. The car will start and run until pressure goes back to zero.
Anyone have any ideas on what to look for -- or what is wrong????
thanks.
thanks.
