mholhut said:IIRC, his handle used to be Russian007... His name was Ilya and he used to be a member of LLSOC a few years back.
02LSE96LSC91SE84TC said:Multiple cars help.
'03-'06 LSes already have "cleared corners" from the factory. It's easiest to see if you look at the "Before" and "After" pictures in the linked auction; the Before has standard amber corners; the After has cleared corners. In the Before picture, the turn signals in the corners of the headlamp assemblies have an amber reflector/diffuser inside the headlamp assembly; the After has the amber lens/diffuser removed. With the stock assembly, you can use a clear/white turn signal lamp; with cleared corners, you should be using an amber lamp.Dartastic said:And excuse my ignorance because I never really paid attention but what are clear corners?
SoonerLS said:'03-'06 LSes already have "cleared corners" from the factory. It's easiest to see if you look at the "Before" and "After" pictures in the linked auction; the Before has standard amber corners; the After has cleared corners. In the Before picture, the turn signals in the corners of the headlamp assemblies have an amber reflector/diffuser inside the headlamp assembly; the After has the amber lens/diffuser removed. With the stock assembly, you can use a clear/white turn signal lamp; with cleared corners, you should be using an amber lamp.
