check engine light help!!!! 2
cinz4064
staten island
i replaced the t toward the back of the intake but i also noticed when the engine is running and i pull the pcv valve out of the motor it runs the same with it out i pulled the vac line off the valve then it ran like :q:q:q:q
Put a new PCV valve in it.. that seems pretty straighforward.
did lol but im trying to figure out a loss of power and gas milage check engine light lean mix banks 1 & 2
If that rubber T was deterioriated to that extent, you might want to give a good look to the "rest of the rubber" in the engine compartment.
Sounds like you still have a vacuum leak someplace.
Might have to get a can of starting fluid and spray it around until you find it.
Should have posted a follow up in your previous thread, rather than scattering this information into seperate posts.
now you'll find yourself repeating alot that you have already said...
can someone post the link to the other thread in this one?
how's the weather on the left coast brandon?
miss your car yet? or are you still lusting after west coast exotics and hard to find mark 8 parts?
Welcome to the Mutual of Omaha's Brandons Wild West Adventures!
See KK stalk uber expensive foriegn sports cars
Watch as he walks amongst the twisted remains of cars from yesteryear.
Listen as he talks about the car he left halfway across the country in the snooooow.
:d:d
now do the IMRC controller thing.. and the supercharged intake tube.
do it do it do it
