Cheap spark plugs......
cableguynoe
Watsonville, CA
What would be the bad effects of having cheap spark plugs?
I think mine has low end spark plugs and am wondering what kind of difference i would see if i upgraded them?...or is it something i should just leave alone?
i dont know sh!t about it.. but i can imagine.. they are the part of the car that ignite and make the car move.. the better the plug.. the better the spark.. the better the car functions.. prolly make it faster somewhat..
Cheep last time I did my plugs I paid like $1.68 a pice for some NGK V-Powers how much cheeper do you want to get? Or are you thinking of iridium plugs?
Any other mods?
IMHO - if your vehicle is stock (or near stock) just stick with stock stuff. You'll piss your money away. Get some Autolites for your car and you're good to go...
nah...no mods.
$1.68? Where did you get those? the junk yard?
I was offered sparkplugs at Kragen anywhere from about $3.50 a piece to 12 bucks each....
I went with the cheaper ones.,....
cableguynoe said:
nah...no mods.
Bennent Auto supply, but the price at Discount and Pepboys is about the same just diffrent brands I dont know about Napa or Autozone but I cant imagen them being to much more. We dont have a Kragen here in South Florida but it sounds to me like there a rip off. I have never paid more then $2.00 a plug even when I bought Bosch platinums. The cheepist i've ever seen plugs is about 97¢ I think they where some autolights.
I put regular Bosch Platinums in on my last plug change. As long as they are name-brand and they fit the car, you won't have any problems. Stick with OEM if you can afford it, but going to something else won't hurt anything... you won't gain anything either by wasting your money on a "performance" plug. All a bunch of hooey I tell ya!
yep! I would just pay for the Motorcraft factory plug and be done with it. It's going to last for tens of thousands of miles, so a couple of extra dollars isn't going to kill you.
The difference between cheap and expensive usually comes down to service life, brand name and coatings.
In general a new plug of the correct heat range and size will work fine regardless of whether it is platinum or not. The real test comes with miles. A regular steel or copper core plug will wear out after about 30K miles or so and needs to be replaced. A platinum should last about 100K although my experience on other brand cars is that they should be changed before say 80K.
On another performance site I have been on there was a lot of discussion about using platinum or regular plugs. For maximum performance, the concensus was to use regular plugs and change on a more frequent basis. For street driving platinums are fine.
BUT, BUT BUT. There have been some problems with leaving plugs in aluminum cylinder heads for the recommended 100K intervals. Many people on other sites have discovered that the incompatibilities(essentially corrosion) between aluminum and the steel of the plug threads, can lead to the plug being very difficult to remove at 100K miles. I hear many mechanics will not change Caddy Northstar plugs and send them to the dealer.
So some people recommend removing the plugs every 50K or so to clean and inspect and then put antisieze on the threads. If it was me, I would remove and replace at 50K, why put in old plugs if you went thru the trouble of getting them out? Plugs are cheap over the long run.
Good Luck,
Jim Henderson
