I accidentally charged my car for an hour before I realized it was on the 6 volt setting. I switched it over to 12 volts from then on. Will this have damaged my battery?
Probably not. I'm sure it didn't charge your battery!
The way a charger works is to hold a slightly higher voltage (like 15-16) in order for current to flow into the battery. By having it at 6 volts, if anything, you damaged the charger by letter current flow back into it from the battery.
