jdouglas22
I have an 01 v6 ls. 140,000 miles. Does anyone have a break down of how to change the check engine light bulb it's been on so long it burned out. Also air bag light came on a 3-2 code I believe. checked under the driver seat for broken wires.. Nothing I take it is the clock spring. All button controls work on steering wheel but when I pull keys out auto seats don't move back anymore. Now that it's cold out I'm not sure this has anything to do with it but the car now shakes sometimes in reverse or idle or come to a stop sign sometimes it happens sometimes it doesn't. But when I get to highway speeds doesn't happen. I am aware of the mis fire issue as I changed all plugs and vcgs and coils from Ebay last year I read on here someone was saying it was a mis fire even though c.e.l is not coming on. I pull codes and only code that comes up is p0401 insufficient flow egr. Changed egr valve/ dpfe and shoved a line down that metal line that connects egr to exhaust to clean any carbon nothing. light is still on. Well not technically on cause bulb is shot. I think that sums up my current problems anyone have any insight or if you've encountered any of these problems and fixed it let me know what you did.
