111 - is usially meens "pass", but not this time.
176 - one time last 50 starts left O2sensor indicated lean. Nevermind, but maybe a dying O2sensor.
524 + 543 - Continuous Memory DTCs 524/543 indicate that sometime during vehicle operation, when the PCM commanded the fuel pump on, voltage was not detected on the power-to-pump circuit (through FPM, PCM Pin 8). Although DTC 524 refers to the low speed output (VCRM Pin 24) and DTC 543 refers to the high speed output, it is not possible to distinguish between circuits due to the vehicle wiring and fuel pump operating strategy. Possible causes:
-- Open in power-to-pump circuit between the VCRM and FPM splice.
-- Open in B(+) supply to VCRM (Pins 4 and 5).
-- Left HO2S short to power. (corresponda to 176 code, where the same circuit showed some trouble)
Enougth?
