brentalan
OK, so NJ has emissions inspection. What they do is hook your car up to the OBDII scanner and as long as there are no codes you get a sticker and go on your way.
I went on Monday. I had no CEL, so I figured I'd be driving right through. They ran the test and said my OBDII system is not in the "ready" state. That's odd since I haven't disconnected the battery in a long time.
I thought, maybe it's the chip doing something odd, so I disconnected the battery and I pulled the chip. It's a Reinhart chip BTW.
I left the chip off and figured I'd drive around for a bit and let it get out of readiness since I took the cable off the battery. Well here I am at 180 miles since then and the CEL popped on. P0174 lean.
I also have an LMS MAF. I remember getting P0174 lean when I first got it and Geno said to clock the MAF around and try again. I remember having some success with that.
I guess I could put the stock box back on and pass inspection. What should I do after inspection? Was the Reinhart chip preventing the computer from learning parameters, thus I was driving around for the past 7 years with a P0174 not knowing? I've run a 14.09 1/4 mile at Atco like this. I want to put my chip and MAF back in but I also want the car running right. Suggestions?
