Cd Player/radio Question-problem
vettetols
virginia beach
tried to put in a cd, hit the load button- display said initializing and then went to cd error. its a 6 disc indash alpine--any thoughts??
mine does that every once in a while. i usually hit the panel on the right sideof the unit. Not the actual cd player but the trim around it, the dash board trim or whatever, a couple good hits and it works! sorry not too high tech but i think that the insides get all dusty and dont function correctly
^ If you can't fix it with a hammer, you've got an electrical problem :D
Is it a burnt cd with a home made label?
Also some cd's both burnt and original vary very slightly in thickness, lots of issues happen with the thickness of cd's in some players
I've had this problem also. Look in the slot if you can see the cd lightly press
down on the top oc it may allow it to eject. Also try turn it off/on to clear the error.
okay thanks for all of the advice:eek: . is there anything external that could cause this? i dont have acess to any service manuals--thnx
