Cat gutting?
MarkVIII93 said:
Have you done it before? On a mark viii, with this same exhaust setup?
GO w/ a tru duel setup.........
He already has a true dual setup. I was thinking of gutting mine as well, but more for the reason that mine are clogged and smell nasty sometimes when I get on it.
I MEAN TWO MUFFLERS MIDBODY MOUNT
Did they used to make guitar strings from cat-gut?
I remember buying "test pipes" years ago at the parts store...for test purposes only;) to see if our cats were clogged......
Midbody mounted mufflers doesnt mean TRUE DAULS! I was thinking about doing that a while ago but there isnt much room and they would hang down.
did you see the pics i post on the above post W/ THE TWO midmount mufflers. i did it w/ spintech mufflers. spintech has thin square mufflers that will alow two midmount mufflers
I actually contemplated using glasspacks like that........
leave your cats alone! they are on the car for a reason. so it will pass emissions, if you wanna get rid of em then buy a whole new set-up.
rmac694203 said:
Yeah but I don't care about emissions, but I do care when my car smells like crap.
I had my cats gutted in my other mk8 and it did not smell more then usual.
rmac694203 said:
I meant that I hoped that gutting my cats would reduce the sulfur smell I get at WOT.
change your o2 sensor. that might help.
Who me? Michigan stopped doing emissions tests a while back....
