Deceleration
The vehicle is moving and you lift your foot off the accelerator. EEC sense’s the TPS go to closed and VSS signal slow. This presents a few problems that are easily overcome. First we have to prevent stalling; this is why the IAB has been open, just in case the throttle snaps shut. After throttle closure the Throttle Air Bypass closes slowly closes. Then it controls idle as we reach a stop and move back into warm idle strategy. We are always thinking of emissions and burning fuel as we decelerate is a big waste. EEC turns the injectors completely off when RPM is over 1500 and the engine is over 140°F. Injectors begin operating under 1500RPM or if you hit the skinny pedal. If you don’t run a VSS you can run the risk of stalling when slowing down from over 1500RPM. EGR is turned off but the canister purge is opened to burn off fuel vapors from the gas tank. Timing can be advanced for two reasons; first with low airflow signals there is little chance of detonation. Secondly, advanced timing helps push back on the pistons, this helps create that engine brake effect.
