mujahid1994
Where do I start??
			How do I shut off fuel?
pull plugs, shut off fuel, see if water comes out when cranking... that will tell you everything you need to know
So how does the car start with out spark plugsI ran thru some deep water too. The motor wouldn't turn over because the water traveled up the exhaust pipe into the cylinders via exhaust valves. I removed the plugs and turned over the motor thus expelling all the water out of the engine. Re install same plugs, bought new air filter and changed oil an filter . It will start up and run .Once water fill up cylinders, the motor cannot compress it so don't try cranking it over till plugs are removed
I thought about that how would I do thatCan you turn the crankshaft by hand with the spark plugs out?
well lets see...
Worst case scenario is that he's gotten water into his cylinders...agreed? (YES)
with no spark, and no fuel, and no pressure in cylinders.... whats the concern?!?!?
IF no water comes shooting out in the 1-3 seconds it takes WITH ALL THE PLUGS PULLED... THEN you can start checking other items.. Oil, electrical, timing etc... NONE of these matter if hy hydrolocked the block originally.
IF you feel you have better advice, I'd love to hear it!
...Rule of thumb here: Never crank your engine if it has had water in it. Any mechanic with half a brain will tell you this.
I will also add that if you aren't a mechanic and you don't know what the effect of your advice will be, it's better to not offer any.
There is nothing at all wrong with removing the plugs and "cranking" the engine with the starter. Even if the crankcase is full of water, any additional damage to the bearings will be too minor to ever notice. This is not at all the same as getting it running with the plugs in and ignoring the oil condition, and that's not what anyone here was suggesting!
If the starter won't turn it, then use a socket on the damper bolt and a long handle and see if it turns by hand. If any water comes out of the spark plug holes, the the engine was hydro-locked and some connecting rods are almost certainly bent (engine is toast). Why not try to find this out as soon as possible?
I drove into some water I didn't know it was that deep I thought i was gonna make it ........................the new battery yet
If it died before the water went in, then why did it die?
If it died before water went in, then there would be no water in now, so no problem.
What do you think the mechanic is going to do first when he gets it?
