Let's see if I can make this work...
Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
Relieve the fuel system pressure. For additional information, refer to Section 310-00 .
Raise the vehicle. For additional information, refer to Section 100-02 .
Remove the left front wheel and tire assembly. For additional information, refer to Section 204-04 .
Remove the left wheel well splash shield screws and pin-type fasteners.
Disconnect the fuel line R-clip fittings.
Remove the bolt at the fuel filter (9155) bracket and remove the filter.
If necessary, separate the filter from the bracket for reuse.
NOTE: When the battery is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
To install, reverse the removal procedure.
The pictures didn't copy, but the text did. Again, the filter is behind the splash shield that is behind the LF wheel...but still inside the wheel well. It's not hard to move.
