Car not starting...battery always seems to be drained...Bad Alternator or what is it?
  • Thread starter Thread starter Classick Rider
  • Start date Start date
C
Classick Rider
Guest
This is getting on my nerves she wont crank and after trying to jump the car it turned on but after a few minutes it died.
get a volt gauge sounds like a alternator between 13 and 14 running they are east to replace
Cool.
Now, repair or replace the rest of the items in your charging system. The other method is to properly test each one (prolly the alternatior and regulator) until you located which is the bad unit.
If you have an aftermarket radio, disconnect it before trying to trouble shoot the car.
If you have an aftermarket alarm, disconnect it before trying to trouble shoot the car.
If you have an aftermarket ashtray, remove the blunts before trying to trouble shoot the car.
check your alt plug to make sure you did not fry it i went threw 3 alts before getting a good one so buy a good one
