Like Icarus said, there is a switch that just clips to the back side of the door lock cylinder. It's not hard for it to fall off. This switch disarms the factory alarm when you don't use the keypad or the keyfob. Pull the door panel, look up by the rear of the lock cylinder. You should see a little plastic piece with a couple wires coming out of it, it should be attached to the rear of the lock cylinder, if it's not reattach and then test.
