Can't hear Fuel Pump
DId you manhandle the gas tank with a BFH yet?
^that mod only lasts for a few days or maybe a week^. When they're done, they're done. I've done a couple of them the same way. I know overfilling will ruin your vapor canister & leave you smelling fumes, i'm not very on top of that issue, I just make sure not to do it!
It's just best to not overfill, over and over. once the pump shuts off, give it one more, maybe two and I'd stop there. I stop on the first shut off or $50.00 and I know I have enough gas to get where I'm going.
Well, I thought I would bring this issue back since I finally drop my gas tank and removed the defective fuel pump and replaced with a BBK 1622 and before I re-install the tank I would like to also replace all of the hoses that connect to the gas tank. Is there a kit to replace two filler neck and jumper hoses? or should I go to my nearest AZ and just match up the hoses as close and I can.
