I replaced the balljoints just last year and now I have discovered that my bushings on the control arms are bad. Are we able to only buy those bushings or are there any poly bushings that fit in there?
Ebay has some bushings but I opted for the whole arm because if you damage the aluminum arm pressing them in or out you will be out the cost of the bushing and a new arm.
This sucks. So, there was no point in me going through the cost a trouble last year doing my lower balljoints. :frown:
The ball joint presses into the steering knuckle, not the lower conrol arm. If you get a new control arm, you will not be changing the ball joint. So you didnt waste your time or money.
Rear lower control arm bushings:
http://www.lincolnvscadillac.com/fo...-lower-control-arm-bushing-replacement-(pics)
Should have asked. Front or rear control arms before
Has anyone used the DORMAN Part # 521617, 521618 lower control arm? I have never had anything from Dorman.
