Caging / Roll Bar for the LS - Discussion
Lincoln LS
  1. DeviLSh
    DeviLSh Dedicated LVC Member
    634
    145
    Apr 26, 2007
    Des Plaines
    Only know of a few people that have ran cages, who might even still be around. But wanted to toss this out there for anyone who was had a custom one built before, know some of the do's & donts, and maybe has some LS/DEW98 knowledge that would be useful as I begin to look into building something for my LS.
    My primary needs are safety, harness support (shoulder bar), rigidity, and to some extent looks/aesthetic. My car will be used for primarily drag strip visits, maybe the occasional track day/fun laps, an otherwise car shows/cruises. Looking to do a Half cage for the rear only Something like a main hoop, harness bar, pair of rear downward bars, and likely a X-brace or diagonal brace across the main hoop.
    Some of the questions I have are:
    1) Best places to mount the hoop, down bars, and any cross bars
    2) Bolt in or weld in, pros/& cons based on LS body structure or material?
    3) What size dia tubing for the LS?
    4) estimated weight add-on for the setup.
    5) Basis or reasoning to add anything forward of the B-pillar?
    Thanks in advance for any insights.
  2. DeviLSh
    634
    145
    Apr 26, 2007
    Des Plaines
  3. HRLNKN
    HRLNKN Well-Known LVC Member
    277
    29
    Jan 8, 2010
    USA
    Quick question: are you planning to run in a particular series or at at particular track? Whatever you end up doing just make sure you're up to their regs/specs. Might be best to have it done by a shop with experience, 'cause it'll cost you more to have them make it right later
    • Agree Agree x 1
    • AmsterDutch
      AmsterDutch Dedicated LVC Member
      2,108
      370
      Jul 9, 2017
      Midwest
      I can't agree more with HRL ....I am a Motortrend Channel junkie...yes I have a problem lol ...anyway after watching Texas Metal, Junkyard Empire, Fantomworks, and many many more full custome garages do this kind of work I had no idea everything that was involved to do it not only the right way but like HRL said what is regulation at many tracks
      • Like Like x 1
      • DeviLSh
        634
        145
        Apr 26, 2007
        Des Plaines
        Yup noted - it all makes sense. I am not really building this car for any particular "class" or competition. I take it to the local drag-strip, who references IHRA tech sheets on their website, and I have also been referencing the NHRA rule book. But most of these go by a type of car class which my hodge-podge build doesn't fit into. I can see myself going to a couple club days or laps at a road course, but never really to compete. (No drifting either, sorry Alz & Stu, haha). So all that being said I am still a bit lost on which "class" this fits into, and therefore what cage I would need. Obviously I am tryin to see how fast I can get the LS on its stock motor/trans. (a high 12 at best?) but eventually, I want to look into a Jag swap, supercharger, nitrous, etc. Some sort of power adder once I get the rest of the car ready for it and squared away.
        I am leaning towards a 5 or 6 pt cage. And am just learning some of the basics so far. These two links have been especially helpful in getting me started.
        https://24hoursoflemons.com/wp-content/uploads/2017/06/How-To-Not-Fail-Lemons-Tech_v3.5_040419.pdf
        https://blvckflagd.com/tech/roll-cage-101-first-time-fabrication-part-1/?v=7516fd43adaa
        I get that every class will have rules, but there has to be some sort of happy medium where I can "overbuild" the setup so that its good for what ill be doing I would think. Maybe its not that easy to just back into though.
      • 04_Sport_LS
        04_Sport_LS Dedicated LVC Member
        3,869
        490
        Jun 12, 2012
        Somewhere around Lake Erie
        Devl,
        Did you ever get that snapped off rear suspension cradle bolt out of the frame?
        I took a small Va-Ca from here around that time.
      • HRLNKN
        277
        29
        Jan 8, 2010
        USA
        What tracks are you most likely going to go to? Try to find out what class they're going to put you in. That's what you gotta worry about
      • DeviLSh
        634
        145
        Apr 26, 2007
        Des Plaines
        Yes - check my build thread - Ended up welding in a threaded coupler. Remote welder/fabricator came to the house and did it on site. Subframe bolted up nice and snug.
        Great Lakes Dragaway and Autobahn Country Club most likely. Will dig in there, thanks for the guidance.
        • Like Like x 1
        • 04_Sport_LS
          3,869
          490
          Jun 12, 2012
          Good to hear.
        • oddball
          oddball Dedicated LVC Member
          1,265
          62
          Aug 18, 2010
          Dallas, TX
          The main problem is you need a someone to build and install the cage. Find that person and let them do whatever they're willing to do and you're willing to pay for. Note that things like keeping the interior intact, and especially integrating the cage into the interior, will dramatically increase the price.
          1) Close behind the seats for the belt bar, down bars wherever they land, cross bars wherever they land. The B pillar is pretty far forward on this car, so the hoop will be blocking the rear seat entry. Unless you're really short and keep your seat really far forward.
          2) whatever the builder wants to do. There's lots of aluminum on this car, so that can make life tough. There's no frame to tie into, so will just have to use large base plates. But, the floor pans aren't really flat anywhere, so it'll be a PITA.
          3) Whatever is required by class, or whatever the builder wants to use, or whatever you can afford
          4) depends on how much you spend (exotic lightweight stuff is expensive), but probably 100 lbs
          5) the front part of the cage is what saves you in everything except a plain rollover. Bars out past the firewall dramatically increase the stiffness of the overall car.
          Now, the kicker is that it's unlikely you'll be in a class that requires a cage. The LS just isn't quick enough. NHRA (IHRA is very very similar) starts to require a cage at 9.99 seconds (in the quarter!) and faster. Beginner road course classes run folks spaced out or just a few at a time and they're not going to require a cage because it costs so much. Autocross doesn't require a cage either because you never really build up speed. So you can mess around, see what you like, and if you get serious in one type of competition then you can work your way up the ladder and, maybe, eventually, need a cage.
          24 hours of lemons has a lot of junkers, there's a lot of cars on the field, most of the drivers are amateur, and there's a lot of contact, so they pay more attention to safety than is justified by the cars themselves. And no one cares about looks, so you rip out the interior and work from scratch.
          • Like Like x 1
          • Agree Agree x 1
          Share This Page
