Built 93 Camaro Z28
BAD LT-1
Southern IL
355 Ci
Forged Lunati Crank and Rods
Moly rings
Forged Pistons
Custom Grind Comp Cam MY SECRET
Heads are fully Ported and Polished
2.02 I and 1.60 E.
1.6 Rocker Arms
GM Peformance Intake
Electric Water pump
Proform race mainbody 750 cfm
billit metering blocks
HURST Shifter
Full MSD Ignition
Hooker Longtubes w/3inch exhaust.
New fuel pump Walboro High Volume High Pressure
Strange 12 Bolt with 4.10 gear SPOOL Painted Red
BMR Lower Arms
Sphon Heavty Duty Rear sway bar
Sphon Torque Arm
HEAVY DUTY STEEL DRIVESHAFT 900hp
Driveshaft Saftey Loop
Sub-Frame Connectors
Race Built T-350 TRANS
Neal Chance converter
Trans Cooler
Car is in real good shape!
Also has cowl hood.
Car is ready for Spray!
Put down real nice numbers at the Track after it was tuned.
Brand new Hoosier Slicks in the rear on a Weld Pro-Star wheel
Skinnies up front with Prostar as well
New Brakes all the way around
Motor and rear-end have about 500miles on everything
Just about $22,000.00 In everything.
Car is set-up for the strip but can drive on the streets, I DID.
I will give cam specs and track times to serious inquires only.
Car is a green grey metallic.
Asking $12,000.00 or O.B.O.
Any other questions call 630-669-5988
Thank You! -Stewart
