Build thread: 98 lsc
Sooooo Expensive learning mistake :( I bought a driveshaft off ebay thinking it was a one piece because I thought the "two piece was a 2 piece meaning it was two driveshafts with a carrier bearing.... Well today I pulled my old one and swapped in this one that I had referbed and balanced etc only to see that they are all one pieces but mine has the insert that I guess a 93 does not. Oh well It is fresh and balanced so I should be ok as I am only installing 3:55's but I was rather annoyed at my self for not knowing.
Got the hardware for the brake brakets bought and got the center back in the car with the new poly front mounts.
Front brakes and hub swap = Done
Rear center swapped with 3:55 and posi =done
REALLY expensive "two piece" drive shaft = installed
Rear hub and brakes swap = 1/2 done (side note for future people , just buy dlf's brackets and be done with it)
Still left to do is:
buy new lug nuts (mustang uses larger ones)
finish rear brakes and reinstall axles and spindles
hang the new exhaust
detail
lol and I leave Friday morning ..... FML
