I have searched for the last hour and only found the below. I went to my parts store and they said all north-american use 3/16" imperial. so I bought 3/16 line and imperial unions to match. I thought I could make the rear driver side and cut and flare it under the door before the rust spot. I spun off the nut and noticed a bubble fitting, so I couldn't use line or unions I bought.
What type of fitting do I need for the rear so I can start there and bend it till reaches the door and then only need to double flair in that spot - one of the threads state you can use the double flair tool to make a bubble double flair? is that true? I found tools that allow you to flair "in line" meaning flaring lines already on the car.
Rear Brake Line Replacement
Brake line thread size?
Brake line repair
Brake line repair
