brake problems???? 1990 TC
Madme
New Brunswick Canada
Brakes on the 1990 Town Car
I've been getting some weird brake problems. Under normal braking everything is fine but when i brake harder the car pulls to the right hard. Usually the brake pedal is soft but when it happens the pedal is harder to push down. I replace the rotors and pads but I'm still having the same problem.
Could the left caliper be sticking open?:confused:
Sounds like a "Diagonal Split" braking system. The left front may not have as much pressure under a hard application. I am not up to date with your braking system but it may be a 'master cylinder' or a 'control valve' problem. Some of the other guys on here may have some technical advise to answer your question... Good Luck!
Could be a bad ball joint, caliper, master,and if you have it problem with ABS module or sensors
