brake problem?
dudez_link
virginia beach
just changed the brake pads and now theres noise coming from the wheel well. it sounds like the rotor scrapes the pads as the wheel turns. it speeds up as the car does. im not sure if i did something wrong (ive done brakes before a few times with no problem) or if theres something else. warped rotor maybe? any insight is greatly appreciated.
just replaced my brakes and rotors also... are you talking about rear or front? i guess you could try scrubbing the area down with brake cleaner... alot of the ceramic pads will make noise if they're not cleaned well... just a thought...
i did...ive done breaks at least 10 times, never with any problem. so id say im fairly proficient in it. the pads are in there good...snapped right into pace and tight
ive done brakes over 10 times, never with any problems. so i consider myself pretty proficient in replacing them. the pads are in there good and tight...snapped right into place.
