aggiestckl
im doing the pads.. is it necessary to put the shims in.. if they are left out is this the cause of sqeauking? also when i tried to put the shims in the pads didnt fit.. and i did use the clamp to compress the pistions all the way in.. but when i leave the shims out their is a gap in were the pad sits against the piston and the other side... also it seems if i took of those clips on the pads this woudl solve my prob.. or would that just end up getting myself killed
