Brake booster or vacuum leak ?
Dougviii
Montgomery Tx
I think the brake booster on my 130k 93 mark8 has failed but before I replace it I thought I would ask for advice, the brake pedal has gotten very hard, brakes still work just takes alot more muscle, I also noticed the a/c vents are acting up, not just under braking but can't find any vacuum leaks. Is this a common problem? Anything else I should check or do before I replace booster?
Sounds more like an overall vacuum leak to me, but it could be a really bad booster.
If you unplug the vacuum line from the booster and cap it (the line), do the AC controls return to normal?
Its definitely the brake booster, looks like a bear to get outta there, anyone here ever change a brake booster?
