Bought LS now P0452
kjw86ca
Victorville
I just bought a new (to me) 03 Lincoln LS...has about 52k miles on it.
The issue I am having is that about 2 weeks later after buying it I am getting "P0452 Evaporative Emission Control System Pressure Sensor Low Input." The light goes off every few days and then the CE light will come back on... what could be the cause? Please help!
Thank you,
Kyle
check the evap system that is mounted to drive side strut mount... the wires could just be loose... also it is a evap smog problem... should be covered under factory warrenty
You may want to invest in a new gas cap before you do anything expensive (like taking it to the dealer)...
Can anyone give me more info on how to check the sensor on the drive shaft sensor is that you are talking about? my last car was a 98 taurus SHO im not familier was the Ls too much. Thank you.
