Blinking CEL
De-marko
VC KS./sticks
If it starts blinking on you when you drive, that means misfire right?
I have three codes that have popped on, one being running too lean, defective catalyst, and EVAP vacuum leak.
Well those three codes are the hard codes. When the check engine light blinks, it is usually when I am accelerating, but the car seems to be running ok.
I need to get a scanner for myself.
That would make sense because the drivers side cat sounds like it has a hand full of loose marbles rattling around in it. Hence the code I suppose.
