Blend Door Arm Removal , HOW ???
Sonny Day Out
Chesapeake
All,
I bought two New Motors that had been reinforced , but I can not find them ! How can I remove the arm from a new motor to reinforce it with compression ferrules !
Thank You,
Sonny
use force sonny, the new ones are pressed on very tight. you can use a flathead screw driver to pry between the arm and the case to get it to release off the shaft, it feels like the amount of pressure you apply will surely break it, but it wont, its very forgiving.
I totally forgot about this. Don't feel like buying a fourth blend door to replace again. Will try this.
