rgorke
I got everything back together after my overheating episode, new radiator, DCCV, and upper hose. Everything else is 3-4 years new.
I bled the system using the manual's procedures twice but the temp keeps rising up into the mid 220s. I always monitor the temp via my OBD2 reader.
My thinking is that I was a bit hasty in filling through the fill top at the thermostat and have air pockets, especially with a new radiator.
What might be the best path forward?
Start over and patiently refill at the thermostat housing or use one of the vacuum fillers (radkitplus) to bleed out the system? Everything I have seen with the Radkitplus is that the cooling system is empty and then you pull a vacuum. Also, I presume the device attachs to the degas bottle or does it attach to the thermostat housing?
Finally, I am 99.9% sure I don't have a leak since everything has been replaced with Motorcraft parts in the past 3-4 years (except the DCCV and upper hose).
