vandarela I think you might be missing the point. with the tbw system yes it does go wot with light throttle input...and if the system is armed it would case the system to spray. so just put a switch on it and you should be all set.
beaups said:vandarela I think you might be missing the point. with the tbw system yes it does go wot with light throttle input...and if the system is armed it would case the system to spray. so just put a switch on it and you should be all set.
