BEHOLD VICTORY IS MINE........kind of
topher5150
Grand Rapids, Michigan
i finally got the cobra intake working. now i just need to fab up the throttle cable and a couple of vacuum hoses. dose anybody know if you still can get the two vacuum hoses that run off the air intake tube for the cobra, the one that goes to the IAC and the one that goes to the valve cover?????
its not a vac hose, not sure what they call it, iac hose, bypass hose? dunno, hit up max he can help you
That IAC hose needs to go to the metered air side of the intake tube. At least it does on my Mark :)
need a cobra throttle cable ?I have 2,one used one new.50 bucks used 100 new shippedany questions,call 386-490-6445 leave message on voice mail and i will call you back
I imagine pulling the throttle cable would be a bitch with the motor still in the car, I've only pulled them after pulling the motor.
