2000sport
So after hearing a clunk that I thought was associated with the sway bar bushings ended up being the ball joint I just replaced.
The shop that installed the ball joint failed to tighten the nut on the stud enough and it backed out, causing the ball joint stud to round off the hole on the lower control arm (steel always beats aluminum) and basically I was a few miles from snapping the ball joint stud...
It was scary getting on the highway with the car violently hooking left or right (completely randomly) I basically had no control over the driver's side wheel.
so... the damage is...
I need a new ball joint (the threads on the stud are toast)
and a new lower control arm
My guess is the shop either reused the OEM locknut (big no-no since nylon locknuts are no good after one use) or they :q:q:q:qed something up and had to unbolt the ball joint from the lower control arm and then reused the new locknut again (still a big no-no since it was already threaded on there)
So its going to the shop tomorrow morning, and since it's been less than 2 months since the install, Im hoping they back up their work and eat the cost of a new ball joint and lower arm... I'd even pay for the new ball joint and have them do the pass side and the sway bar bushings if they cover the labor and parts on the lower arm...
ugh
FML
ugh
FML
