panthermike
I had my front end inspected today. My mechanic said that the tie rods were dry and needed to be greased(showed me) and said the driver side lower ball joint is bad.
The dealer says you have to buy the ball joint with lower control arm assembly for 186.00. Parts houses tell me I can buy just the ball joint. Can I? The ball joint price they gave me was 70.00.
Also, I took it in because the wheel doesn't "return to center" after turns. Could a ball joint cause these issues? He said if the ball joint doesn't fix the issue then I'm looking at replacing the rack and pinion assembly, ouch!
