mrfuzz
Alright,
Been a very rough day. One thing after another. Well after running all day long doing service calls -- Computer work
I stopped to a customers house to hear a "hisssss" Come to find out I punctured my Front Left tire -- I had a small roof nail stuck -- Thought it was fine. However it was not, and it did go all the way through.
Well, Upon changing the tire with my spare in trunk. The tire is SHOT. Its wore really bad on the inside. all other tires are fine. Luckily its under warrenty. In the morning Im getting it replaced -- For now
Upon removing tire, my threads are stripped. so i went to local advanced auto and picked up the Chrysler sebring lug nuts -- threads fit and they go all the way on.
Moreover,
I take the car to the local Tires Plus to have alignment checked.. I was right there with them under the lift looking. Here is what we found / They found upon inspection.
RF upper control arm
RF Lower ball joint
LF Lower ball joint
RF outer tie rod
LF Outer tie rod
Now there was play in the tires, they wiggled about maybe half inch both ways.. Would that be the tie rods or ball joins?
On top of this, I noticed my back rear pads are SHOT -- Almost NOTHING left.. So tonight im ordering the Rotor Pro's brake package.
Mind you. I just placed all 8 plugs and coils
Opinions.. And what should I do here.
Moreover,
RF Lower ball joint
LF Lower ball joint
RF outer tie rod
LF Outer tie rod
