bad switch?
Mill1978
bolingbrook
My auto headlamp stay on even during day light hours. Does anyone else have this problem. I think my switch is bad.
Its not in the switch have you checked your photoelectric sensor, on the right side on top of the dash, if it is not getting enough light then the lights will stay on at all times, I had the same issue until I peeled the windshield tint, since I have 5% all around and had 50% on the windshield.
the center of the photocell " eye " gets burnt over the years so the sensor thinks its dark out all the time. you need to change it, its an easy change, should be a cheap part too at the dealer if they are available, if not, i have plenty of used ones.
i had the same problem.. then i took my license plate out of the windshield.. and whattaya know...
turns out I was the problem ..haha
That sounds like something my wife wound do LOL. Thanks for the info ill check that in a few hours.
