Was on my way to work and turned right and the back end started bouncing something crazy. I pulled over and the back was slammed to the ground.
The only thing I did was put the summer tires in the trunk/back seat, as I bought a TPMS and was taking wheels to have sensor installed.
at first I was sure the sensor fell off. After trying several different things, I raised the Asham 8 to the max position and the front raised to 4x4 height. Then the back raised enough to get the quarter panels off the back wheels. Drove her a bit and the back raised to normal height, while the front stayed high. I installed a switch in the cockpit, so I could turn this off while in the interior and did so once I had decent height. If sensor was off it wouldn't have raised back up so...
This must be a defective Asham 8 module, no? One thing I should mention is the fuse blew for the driver module (processor that monitors driver door, seat memory etc. - it turns off the radio/acc once you remove key and open door) now I can open driver door and the radio stays on. This fuse went about a 1.5 years ago. I replaced it and it was fine. I have to get 15 amp fuse, so I haven't replaced this yet - still no way that could slam the car - I could see it not allowing the front to lower as sit waits for the person to get out and close door before dropping ride height.
