Phlox
Seeking help from Joegr, 1loudLS, Andrizzle, LS4me, RollinLS, and any other audio enthusiasts/ knowledgeable folks here at the LvC community!
So, now that I have done my planned upkeep maintenance (I need to update my original post regarding the mechanical maintenance I had planned) to my Gen II 2005 Lincoln LS 3.0L V6, I now have plans to update my entire sound system. The caveat is that I have some questions pertaining to this matter. Let me provide some background info about my car's current system, before I start asking questions, so I don't get flamed here (and yes I have read/researched a fair amount of previously posted audio topics going back 6 or 7 years.)
Build Date: November 2004
Current Mileage: 79k
Current Head Unit: Single Disc / Cassette Deck
Current/Stock System:
Car does NOT have factory amplifiers
Car does NOT have multi-disc changer
Car does NOT have rear deck mounted 6x8 subwoofers
Car does NOT have center console mounted 2.5" mono speakers
Car IS EQUIPPED with ONLY the 6x8 speakers in door panels/skins
Updated PURCHASED equipment:
Head Unit:
- JVC KWV-10 Touch screen DVD Multi-media Receiver
- Has 3 sets of 4v outputs for Front Rear & Subwoofer
Door speakers:
- Rockford Fosgate (Prime R168X2) 6x8 2-way Full Range
- Power rated @ 55w RMS/ 110w MAX
- Frequency range @ 51Hz-20kHz
- Purchased four for both front and rear
- The integrated tweeters have a built in High-Pass Crossover
- ALL speakers will be wired into and powered off the amplifier NOT the head unit
Subwoofer:
- Rockford Fosgate (Punch Stage Two P2D2-8) 8" 2ohm Dual Voice Coil
- Power rated @ 250w RMS/ 500w MAX
- Minimum frequency is 40Hz
- Only plan on installing ONE subwoofer
- Box will be ported, fiberglass-fabricated to match the recommended airspace specs, and form fitted into my trunk
- Will be wired in @ 4ohms to the amplifier
Amplifier:
- Rockford Fosgate (Prime R600X5) 4-Channel + 1-Channel Mono
- Power rated @ 50w x 4 RMS & 200w x 1 RMS 9(Mono) in 4ohms
- Dynamic Power @ 55-58w x 4 RMS & 220-225w x 1 RMS (Mono) in 4ohms
- Amp has frequency & gain adjustments on all channels, plus HP-AP-LP crossovers on speaker channels only
Sorry for the length, I just know that many LvC members like to have as much information provided as possible before answering questions. Now that that's cleared up, I suppose it is time for the questioning.
1.) My first question relates to the tuning of all my components, in-order to produce a clear and clean sound; in addition to, preventing any clipping issues. When setting my gains, frequencies, and crossovers on my amplifier; do I also need adjust the settings provided on my head unit, i.e. Equalizer, Bass Boost, Curvatures, Cross Overs ect. (head unit also has a separate menu for subwoofer adjustments) or should I leave those settings in a 'flat' configuration and let the amplifier do all the tuning adjustments?
2.) I would like most of my bass to come from the rear of the vehicle and the treble to 'scream' up closer towards the front, so when adjusting my frequencies on the amp should I set the SUBWOOFER frequency around 100Hz, the REAR around 95Hz, and the FRONTS slightly higher than the REAR -- say around 110Hz or 120Hz? Yes...No...any thoughts? Should both the REAR and FRONT crossovers on the amp be set in HighPass or should the REAR be set in ActivePass and the FRONT set in HighPass?
3.) My third question is in reference to my parking brake wire on my head unit. Since I have a Gen II model Lincoln, I am aware that there is no parking brake signal to connect my head unit to, so I am asking for some of the best suggestions for a work around for this head unit model. I have read a couple other forums that state that these newer model units cannot simply be grounded to bypass the parking brake feature. I've seen others use 4-pin relays, "micro-bypass" harnesses available for purchase, and examples of people using spare wire and inserting it into the head unit harness then looping it around and connecting it to the brake wire on the unit. I'm perplexed with this issue!
4.) Where can I tap into a RAP (retained accessory power) wire? Although I don't know if I plan to utilize this feature seeing how I very rarely listen to the radio longer than a few seconds after I turn off my car, and I always power down my stock head unit before opening my door...something I've always done in my previous cars. Any information relating to this from the LvC community?
5.) If I plan to add a reverse camera in the near future, where can I locate a Reverse Signal to tap into? I've read about wires in the rear that can be tapped into but if I remember correctly they are negative signals and don't always work properly with other members head units. Are there any hiccups I need to be aware of with this type of installation? If my unit requires a positive reverse signal, does this mean my camera with remain ON at all times and if so, how to I go about solving this by forcing the camera to only switch to ON when the car is placed into the reverse gear?
Once again, sorry about the length of this post, but I was trying to be as thorough and informative about my issues and concerns beforehand to help streamline this Q&A process. Thank you for your time and concern; moreover, I further appreciate any help, thoughts, and considerations regarding my post. Thanks again LvC!
Head Unit:
Door speakers:
Subwoofer:
Amplifier:
